60 hp lower unit
pellis
How do I make sure shifter is in right position when installing/replacing lower unit. Put it back after installing water pump and will not shift into neutral or reverse.
lifeisfun
Re: 60 hp lower unit
I suspect that someone will help you but please give us more info
pellis
when I replaced the lower unit, thinking it was in neutral put it in reverse to back off trailer it was in forward gear, in forward also while in neutral.
