Re: 60 hp Mariner losing power
I have had a similar problem before on my Mercury 60 hp and it was a bad insulator on a wire but I have also had the exact problem on another type of high performance 2-stroke engine.<br /> You could have a week spot on a wire insulator but my first thought is that you are running it lean at high RPM's. You may be slightly rich at lower RPM's but have your high end set too lean. I have experienced 2-strokes be set rich on the low end and lean on the high end. What happens is at the lower end, fuel/air mix can build up in the lower end and as the RPM's come up, the excess is neutralized until it becomes lean on the high end.
A 2-stroke that is run lean will build up excess heat after some time (The amount of time depends on how lean). Judging from what you said, something is getting hot.<br />Also, check all the wires in the ignition system for cracks.<br />As for the stator, in my experience with 2-strokes, if the stator goes bad it is fairly consistent on acting up (Meaning not just when warm). BE SYSTAMATIC IN YOUR APPROACH
<br />GOOD LUCK<br />
