60 hp merc 1995 tracker Pontoon
RussFarmland
I have new battery new horn button but still every time you turn the key to on before engine is engaged the alarm under dash starts beeping after engine is started it still beeps
riverebel
Re: 60 hp merc 1995 tracker Pontoon
is it a constant beep or a beep-beep-beep
riverebel
That would be the low oil alarm.Make sure you have oil in tank...or,I have a 60 hp on a fisher pontoon that done the same thing.I replaced the warning module & the sensor in the oil tank which didnt help.It ended up being the float in the oil tank which is not replacable.You will have to buy a new tank.I just unplugged the sensor to the tank,but have to keep an eye on the oil so it dont run out.If you have a manual it tells you how to check the module & sensor to eliminate them,but my money is o the float.I hear a lot of them have to be replaced,which eventually I will too so I wont have to keep a close eye on mine.
riverebel
to check the float take the oil tank loose & hold it upside down with the sensor plugged in & see if the beeping stops
racer8676
riverbel,
im new to the boating scene and just purchased a 94 tracker with a 60 hp mercury oil injected. im expiercing a piercing constant beep at random nothing seems to make it quit except to turn the ignition off. it has oil! could it be a stuck float like you had mentioned? the only difference is aconstant beep and not a beep beep beep! and is very random can happen 5 times in 20 mins and not happen again for 45 mins!
Thanks in advance!
