greg crosby
pitch 19 3blade running 4500rpms. Pinch 19 four blade down how many rpms approx.? Looking to buy 4 blade pitch 19" for alpha?
jestor68
Re: ??
A 4 bale prop will usually run 100-200 rpm slower than a 3 blade prop of the same pitch.
This is provided that you are dealing with the same material and brand of prop; or at least different brands of similar design( such as Merc, Solas, Michigan).
What engine do you have?
MBAKER
Re: ??
Definitely keep the brand in mind, I switched from a aluminum Powertech 3 blade 19, to a aluminum Solas 4 blade 19 and lost about 700 rpms.
