Biggieb400
- May 28, 2012
- 20
Hello outboard Wizards!! I am new to this forum and have already found a wealth of knowledge in the 'Top Secret' files and the FAQ's.
Engine Model - TE60TLCEA
Boat - Sun Tracker 24' Party Barge
Model Year - 1989
I picked up a project pontoon a few weeks back with a 60 hp 3cyl engine. I was able to get the engine running with some ignition and neutral safety switch wiring corrections. The tell-tale restrictor was plugged and quickly fixed while running on muffs. Once I had the wiring resolved, I took the pontoon out for a 'sea trial'. Engine ran great!!
Not knowing the engine's history, I decided to proactively replace the impeller. I got the new style kit, 0432955. During the installation, I noticed that the new housing was a 1 piece SS housing as well as the base plate having a smaller inlet opening as noted in NoECM's post - http://forums.iboats.com/showthread.php?t=544170. The engine also had already been updated or built with the tell-tale/vent in the upper part of the exhaust cooling jacket. I also installed the higher rate thermostat spring.
Took the boat out on Memorial day weekend, engine idled like crap. I assume the first trip out loosened up gunk in the carbs. We got the boat outside the no wake zone and I opened it up to WOT - approximately 4000 RPM. Shortly after that, I hit the S.L.O.W. mode and the buzzer came on continuously. The engine cooled down and we were able to continue with the engine running below 2300 RPM, no issues. Got home, looked at the instructions again, and realized I did not remove the restrictor. Removed the restrictor, ran it on the muffs, pulled the thermostat and it looked okay, as did the thermostat seat. There was a couple small pieces of debris in the thermostat from the water inlet screen. Cleaned that out, ran the engine briefly with the muffs and no thermostat or cover to flush it out. Reinstalled thermostat with new spring.
Took it back to the lake, this time with the infared temp gun. At 2300 RPM, the head temp was 150 -155 degF. Within 2-3 minutes of WOT, the buzzer went off and we hit the derate again. Temp gun showed 160, maybe a little higher at the time of derate. We pulled the stat out, against my better judgement, and it ran successfully at WOT for 30 or 45 minutes. Tried the old spring, hoping it would open sooner with the increased water flow and still had the same problem.
One final note, the temp switch appears to be the old style (solid tan wire). I am hesitant to replace it, as I don't like the idea of the alarm triggering at a higher temp and it didn't trip the alarm on the first trip.
I am ready to pull my hair out. Please give me some additional ideas so my entire boating season isn't ruined!!!
Thanks in advance
Model Year - 1989
Thanks in advance
