Tried to raise the motor today and it wouldn't go up. The Trim motor sounded like it was running, but no go. Anyway after loosing off the Manual release valve I was able to raise it part way but not all the way. I was then give an extra hand in raising it up (manually) when oil sprayed from the top of the Motor housing. Now the question. What would be suggested to replace or repair it as I don't even know what was the matter with in the first place. I know that I will probably have to replace the O-rings and seals. Any advise would be greatly appreciated. 1994 60hp serial 0G071380
