Re: 6100 RPM
The 6100 looks good for wot rpms .However,I'm betting you could use the 13 1/4 X 17 and play with your setup to keep your wot rpms near 6000 an gain some top end as well.<br /><br />What lenghth and style boat is this 70 pushing?What is the engines year model or model number?Where is the engines anti-ventilation plate height in relation to the bottom of the boats hull at transom when trimmed level?Lastly ,what brand prop are you currently running and is it stainless or aluminum?<br /><br />You'd like to have the engine mounted as high as possible without experiencing excessive prop ventilation when executing a tight turn at 2/3 throttle on plane.This allows for the least amount of drag and exhaust back pressure.
