62 75 hp.evenrude
popbear
I have purchased a boat that has a 75 evenrude on it there is nobody in my area that seemes to know how to work on this moter it will start with a lot of trouble.It then runs on 2 cyl.#1 and 3 there is fire at each cyl.the compression is 95 on every one i took the carbs off and cleaned and cleaned the fuel pump.I have two of these engins and I have inter changed the carbs still works porley is there some one that might have the ability to help me i would greatley appricate it.
R.Johnson
Re: 62 75 hp.evenrude
Give a\us a model number. There is only one carb on a 62, 75
popbear
i have posted a message regarding 1962 75 hp. enenrude and i havehad 1 reply and being a new user i am not sure what to do next ands is there anybody out ther that has had one of these engines that might have worked on it . and that is able to help me
jimmbo
Looking up the model number you posted shows your engine to be of 1960 vintage. Not a lot of people are knowledgable of these 45 yr old motors. Initial settings for mixture needles are 1 to 1 1/2 turns out for the low speed and 5/8 turn out for the high speed needle. <br />Your public librairy should have tune up and repair books for outboards that might help you
popbear
thanks jimmbo i do have the proper repair manual they tell how to repair but they dont tell what is wrong with the engine
cjones4@hvc.rr.com
Hi popbear. I have a '63 75HP 'rude. I've found the key to keeping it running smoothly is annual tuneups. Replace points, condensor, plugs, fuel filter. It's pretty easy to do if you follow a manual.
popbear
Thanks mooner when i finaly get this moter going i will maintain it but to get it running that is the trick.
cjones4@hvc.rr.com
Sorry if I wasn't clear. In my experience (I am not an expert) with this motor the TRICK to getting it running is the basic tuneup. I have fixed many different types of poor / not running conditions by doing this. I have cleaned/ regapped points and plugs with mixed results. For $40 in parts and an hours work you will either fix it or eliminate half the potential problems. Good luck.
popbear
thanks mooner i to am not an expert i know very little about these things i have elimiated points> done a carb tune up< done a compression test every thing is good checked the reid valves they are in order.the engine will run on 1 and 3 cylinders but will not run on 2 and 4 that is where i am at now.
fireman57
You say that it will not run on 2 an 4. I assume that you have checked for spark and found none. Is this the case? Check your ignition coils for cracks in the plastic. If you can put it on muffs or better yet in a barrel of water and crank it at night you may see the spark arcing to the block or a mount. If your coils are cracked replace them. You say that you have eliminated the points, does that mean that you replaced them or went to some kind of CDI? When you change the points make sure that you grease them them lightly on the shaft or they could stick. Make sure that you change the condenser too. Check to make sure all wires clear the flywheel when it spins and torque it down to the correct pressure. Check and make sure that your flywheel key is not sheared or sloppy.
popbear
thanks fireman57 there is some things that you mention that i have not done. I will try them tomorrow there could be a problem lurking in the coil. I will let you know i will be going up to labador fishing salmon next week i am going to work hard before i go to find out what the problem is thanks again> popbear<
