62 Qd23 10 hp Johnson shift adjustment
Freeman79
I'm having trouble seeing how to adjust my shifter on this classic. It easily goes into reverse but difficult into forward. Please help.
nwcove
Re: 62 Qd23 10 hp Johnson shift adjustment
remote controls ??
Tell more of the story !--------New to you motor ? ---any work done on it recently ?----Oil in the lower unit checked ?----Is it jumping out of gear ?
HighTrim
Are you trying to shift out of the water, on a stand? You will need to turn the prop as you shift into gear.
Freeman79
I had the lower unit out recently, I only saw one position I could re-assemble the rod at the brass coupling with two bolts. The oil in the lower unit is good. It has jumped out of gear when I did manage to get it into fwd.
Freeman79
In the water, at the lake with motor running.
AlTn
if it was shifting well prior to dropping the lower unit the mostly likely thing is you haven't got the lower and or the upper shift rods back in the coupler correctly....using needle nose vice grips to hold the rods in place while installing the screws works pretty well for me
Freeman79
I thought there was one detent in the side of each rod that the bolts fit into. So there is room for adjustment at the coupling?
Screws have to be the notches.----No adjustment there.------Adjustment is at the lever / shifter handle.
kfa4303
Banned
To change gears, you flip the lever on the left side of the motor. The shift rod linkages are on the side of the motor behind the small oval window. This link should help.
Johnson
