Re: 62 seahorse 10 bottom motor cover
Hi Gain,<br /> Between the studs you've noted is a rubber bushing. Originally the studs were bonded to the bushing on both ends. However, with age and use the studs can shear off and the cowling is no longer connected to the mounts.<br /> There are a couple of possible fixes. Check with your local Johnson/Evinrude dealer and see if they might have some in stock - you never know. If not, get creative. You can make something similar to the originals by using a section of 1/4" I.D. fuel line as a bushing and sliding it over a bolt to similate the bushing's shock absorbing affect. Basically, create a rubber sandwich, such that the bolt comes in through the bottom of the mounting bracket, with a flat washer next, followed by the hose (about 3/4" section), followed by another flat washer, followed by the cowling, follwed by a Nylock nut. Use 1/4-20 bolts, preferably stainless, in a length that approximates the original bushing's length including the studs. Do not simply bolt the cowling to the mounts, as vibration and such can crack the mounting brackets. It'll also make the motor louder as more vibration is translated into noise in the cowling, etc.<br /> I don't know if there's enough clearance between the cowling and the brackets to sneak the old bushings out and get the rubber hose piece in there. without having to remove the powerhead. If you do have to remove the powerhead, it's not a huge deal, but does add another step to the process...<br /> Good luck!<br />- Scott
