fireshadow
- Jul 25, 2010
- 29
Tried to start my new to me 63 18hp evinrude yesterday to no avail. I fugured that I would be rebuilding the carb after I saw that the fuel filter was completely varnished. Thought I would try it anyway. The only way she would start was full throttle with the low idle jet all the way in, even then it would only run for a few seconds. I have the factory service manual, but the instructions are a little vague on carb removal. I have the choke lever off and the throttle likage. How do I remove the low idle likage valve arm and the high idle adjustment knob. Do these just pull off? Also had to remove evey visable nut on the starter to be able to reach the left nut on the carb to motor mount. Where is tje remaning nut for the starter? Thanks guys
