craveman85
- Jun 15, 2010
- 107
i have a 63 evinrude fastwin 18hp. it doesnt seem to like slow speeds much. if i throttle down to the idle screw on the throttle it would always stall out. it is pretty shakey at idle and paritial throttle till i get into the high speed circuit. so after some pondering i took out the low speed needle. the washers were disintegrated in there. i cleaned them out and put in some new washers with an o ring to seal it better. i put the needle back in and backed it out the standard 1.5 turns but it wont start at that setting. about 2.5 turns out it starts and will run at a higher rev and at 3.5 turns out i can idle it all the way down with the idle screw at the maximum rpm setting. any suggestions. i can still putt around with the boat just fine but just cant get the really low rpms and im not sure why the needle needs to be out 3.5 turns.
