63 speedifour 75 HP alternator???
ctaylor2069
Did they make a alternator or a stator set up of some sort to recharge my battery while running? 1963 speedifour 75 HP. Magneto ignition
boobie
They might have made a generator kit for it but you'd have to hunt around.
F_R
Agreed, the belt driven DC generator kit was an accessory. There is more to it than just the generator, including a voltage regulator, regulator cable, deep junction box cover, ammeter, special drive belt, and belt pulley.
F_R
Probably if you search hard enough for used ones. Costly if you are looking for new. For example, the voltage regulator was $100 last time I looked.
steelespike
If your just starting and doing occasionally running lights it will go a long long time say several weekends between charges.
These old systems are really more a charge maintainer And may struggle recharging for a sound system all day, trolling motor
or fish finder.
If you must have some of these things get a good separate deep cycle battery and charge at the end of the day.
yorab
Ensign
As others have said, the parts can be found, but it probably won't be easy. I found charging system components a few years ago for my '63 Starflite, but it was a LOT of work. But at the time, I didn't mind the "hunt".
If you don't want to be bothered with all of the sleuthing and searching, then do what steelspike suggests and get an extra deep cycle battery for accessories.
