64 Evinrude 5.5 Model#5402b ser# e03879 replace water pump impellor.
jwh
Hi! All,
Would like to replace waterpump impeller. Does anyone know if the power head has to be unbolted to get to the driveshaft shift connector?
I don't want to just start taking it apart and ruin something. Any help would be appreciated. It does not have a window on the leg.Thankyou much John. I also have a 62 seaking 5 HP model#gg18736 that does not have the window either. I want to replace that impeller also. THANKS
bktheking
Re: 64 Evinrude 5.5 Model#5402b ser# e03879 replace water pump impellor.
According to the diagram found here it does.
http://www.marineengine.com/parts/v...ntage-evinrude-johnson/380045/38004500001.htm
Pretty simple actually, remove the fuel pump, controls to the magneto, 5 short and 1 long screw (hold the powerhead on). The powerhead pull up and off, revealing the spring assembly and the shift rod. Replace the top gasket on the spring assembly and the o-ring in the carbon seal. Remember how it goes back together (the spring) glue the top gasket down as well. Undo the shift rod. Pull the 4 bolts from the gearcase and drop it down. Remove the water pump and inspect, you'll know what to replace based on condition. You will also need a powerhead base gasket when reassembling.
Seaking- no clue.
jwh
Wow, That is great.Don't know how to thank you. You have a great day. John Hendrickson
bktheking
I added to the 5 screw and 1 screw, they hold the powerhead on, forgot to say that.
jwh
Thankyou again. Appreciate all the info I can get. John
