I have been trying to get this 40 hp lark going better, it has been worked on by several mechanics the latest discovered some broken link pins and repaired. I just had it out on my 14 runabout and it does't seem to get up to full acceleration. The high speed carb jet is all the way over to rich. When I brought it back in today I found this little lever with a near the accerater, it has a cylinder that spins on the top of it, when the throttle shifter is in med. or low this spinning cylinder is pushed against another moving wheel but when I moved the throttle to high this level with the wheel was lose, as if it is missing a spring? Is this the cause of the poor acceleration?
