Just bought a boat with this engine.
Seller claimed to have recently spent $800 on it. Much new wiring inside the cowl with a new starter solenoid and a new single cable push-pull steering rack. Looks like new plugs and wires but no evidence of much else being touched.
Problems are:
1) Starts and runs fine. Will run well at slow to moderate speeds indefinitely. Idles fine. At full or near full throttle after about 2-3 minutes it surges a couple times like it was given more throttle or an extra cylinder cut in and then slows down and stops like it was running out of gas. Then it will re-start after a few tries and resume operation same as before. Once it seemed the battery was run down even though recently charged upon trying to restart. But after a short period, it cranked as though the battery was fully charged. Fuel delivery from the tank is good. Battery is new.
2) When turned off, the prop freewheels but when running it is stuck in forward regardless of the shift/throttle lever position (fwd, N, reverse.) Shift wires running into the lower housing appear new (blue and green.) Not sure about the Johnson Electromatic shift mechanism but wiring appears new and professionally done there as well.
Questions:
I'm using 50:1 mix. Is this correct? Could the dying problem be overheating at high speed causing it to seize or bind up? Is that why the battery seemed low on restart but after sitting a minute or two seemed OK? I'm getting water flow as though the impeller is OK but do not know if it is sufficient - not experienced with outboards. There is a long narrow SS plate on the lower port side with a 3/8"-1/2" hole which I assume is the water intake. Is this proper? Seems pretty small. Also, the manual choke lever position inside the cowl does not have much effect once the engine has been running and is warmed up. How can I diagnose the shifting problem? Is it possible to jump the wires to test it?
I'm mechanically inclined and experienced with other things but inexperienced with outboards. I've ordered a manual but hope someone can give me a tip or two to get started in advance of it's delivery.
Thanks for any help!
Problems are:
Questions:
