65 Mercury Should I or Should I not?
shuman
I have a 1974 Mercury 65 hp 3 cyl. motor that I pulled off my boat about 2 months because the boat had sat for 9 years with out any gear oil in it...on top of that some one decided they wanted to work on it and pulled the carbs off of it then left them off for another year. This motor is seized up I can turn it by hand with wd-40. My question is should I rebuild this thing, or should I just part it out, or just throw it away? Any one had any expeirence with this type stuff let me know and tell me what you did. <br />Thanks,<br /> :eek:
JB
Re: 65 Mercury Should I or Should I not?
Moving to Merc Troubles.
RICKRICK1
Ensign
I would do what needed to check compression. Even if only hand cranked. Add some kind of light weight oil to the Lower unit. Turn it a couple times then drain the LU and look for rust in the oil. If you have above 90 psi compression I would fix it. <br /><br />If you are going top throw it away let me know.
papasage
shuman i have a motor the same hp. & year. <br />it has sat for 7 years or more i have sprayed gass oil mixture into plugholes and carb. . spun it over with the gass oil mox heaveley . comp was 125 0n all cylinders . [the wd40 doesent have enough oil in it] . i will let it sat for a while . rebuilt the carbs while it sat will try starting it soon when time will allow .use oilgass mix . it may run as is . worth a try .papasage
mellowyellow
all good advice... even if L/U is shot, might end<br />up with a good powerhead.<br />good luck,<br />M.Y.
ledgefinder
Ensign
Lower units from Mercury 40hp (twin) and 50hp (four cylinder) motors will bolt on. The gear ratios will be slightly different, but you can just get a different prop.
ledgefinder
Ensign
You definitely want to change the water pump impeller. They're pretty light-duty on that lower unit, and after 9 years of sitting probably not trustworthy.
