I just bought this boat in Feb, which is my first boat motor. But I was an ASE auto mechanic several years ago, so I'm not totally clueless, just "a fish out of water", so please help! Question: I'm having problems keeping her running, would a weak coil in a magneto create a rich mixture scenerio? I tried one of those spark testers, and couldn't get any light, but it will start and run for up to 30 seconds, but not every time. It seems like the longer between times I try to start her, the more eager she is willing to start, but only for a short time. <br /> For the record, I've been thru the carbs (floats, needles,seats, gaskets), fuel pump, new seals/water pump parts/lube in the lower unit, adjusted the "looks like new" points, put new J4C plugs in her, wires check ok, compression is 105-115, had new brushes put in the starter (per Laddie), no arcing tracks in the cap, nor rotor, and I'm getting frustrated. Do I need to spend that $60 (oldmercs.com) for a new coil, or does someone have another suggestion? Any ideas will be helpful at this point! TIA!<br /> B
