I am having a problem with a 1967 evinrude 80hp Starflite electric shift outboard. I pulled the boat out for the summer (sat for seven months) Added 3/4 tank fresh 50:1 gas. Found I had no spark, found coil had cracked and was bad. I have the battery points/coil ignition. I couldn't find a replacement coil so I put one of my VW coils on and ran a 12 v wire to the coil from ignition. Engine now runs, but I couldn't get enough power to plane out while on the water, only get about half throttle and motor felt weak. Since then I have rebuilt carbs (squeaky clean), new fuel filters, pump bulb. etc... I reconditioned distributor cap, refit all wires (all ohm out great), cleaned and set points with continuity light (points are one year old, less than 10 hours on them). Now the motor idles great, but I noticed as I pulled the plug wires off the port cylinders (2 and 4) it only caused the motor to stumble a little (the engine continues to run with a little difference but not as much as 1 and 3, indicating weak combustion). When I pull the wires from cylinder 1 or 3 the engine will die during idle (indicating strong combustion from 1 & 3). I swapped the wires and spark plugs around and still cylinder 2 and 4 seemed weak (wires and plugs not the problem). This seems to indicate that 2 and 4 are not producing the power they should be and I am not sure why. Both cylinders are getting good fuel supply. When I remove the spark plug wires the spark jumps across to the plug with strong blue spark and I hear the cylinder fire. I refiled the points and put in my spare condenser and set the points with continuity light. Still find that cylinder 2 and 4 are not producing their fair share of power. I am at my wits end!!! Please Help :%
Thanks,
Jason
Thanks,
Jason
