67 johnson 100 hp prop
coryg79
Im looking for a prop for my 67 johnson golden meteor 100 hp.. so far i cant find one online. does anyone know where i could look?? :confused:
Willyclay
Re: 67 johnson 100 hp prop
If you have electric shift with the large gearcase, I may be able to help because I have a 1968 Johnson 100HP.
coryg79
I do have the electric shift. and i would imagine the large gearcase as well :)
Willyclay
I think the props for 1966-1968 J&E 100's are the same but before you spend your money, get verification. Here's a link to BRP's website which still has listings for 1968 models:
http://shop2.evinrude.com/ext/index.aspx?s1=bf6ad09c53cead335fcfd8a6471c0f7f
Additionally, Michigan Wheel lists three props for 1967-77 Model 14 Large Gearcase OMC I/O's which I think are also compatible if the diameter and pitch work for you. Again, try to get verification before purchasing. You should be able to find them through the iboats.com online store.
Good luck!
