I have read with interest years worth of posts related to this problem. You know the one "won't go all the way into reverse". Motor/lower unit have never been apart, I have adjusted linckages etc. my question is this:
how much play is normal for the upper shift shaft. How do the lower and upper shafts connect. I was wondering if there is a coupler for the splines that could be worn. The linkages rotate the upper shaft but i have to push it just a little extra to engage reverse. The end of the crank on the shaft has about 1/2 of play at the connection hole. The reverse lock does not have full travel either, it moves some but not enough to latch. Just trying to gather as much information as possible before removing the LU.
Sorry I think it's a 1969 1000SS, a family heirloom.
Ron
Ron
