55 horse 3 cylinder, 2 cycle. Model #55873R. Man, I wished my manual would come in the mail] First question should the pump pull gas, if I am just turning over the engine, but the engine dosen't start? Next, do I even have the fuel lines hooked up right? On the motor I have a inlet/outlet? with four holes and a I/O with that appears to not have any holes which matches the one on the fuel tank and that is how I got it hooked up. On the tank I have a I/O with four holes and a small plunger on the tip and an I/O that appears to have no holes. How can I trouble shoot the fuel system starting at the tank and how does this system actually work? I tried it both ways to see if the pump wanted to pull some gas to the motor while turning her over and nothing, no gas to the motor via the fuel lines. From experience with four strokes the motor acted fuel starved. I put about an ounce in each cylinder with each try turning it over, in my experience I should have gotten the motor to run if only for a few seconds, by bypassing the carbs, right? I even put fuel in and waited to make sure I was not flooding the motor and still she would not start. I pulled a plug and I am definately getting strong spark. Some one mentioned I can't remember where in iboats that this motor had a set of points, even though the motor is electronic ignition anyone know anything about this? If so where are they and what are the tolarences for the points? Still I appear to be getting good spark, so how can I check the timing on this electronic ignition? Anyways she started to jump to life, but really only "started to" and never made it over the top to actually running. A couple of tries I noticed I actually had what appeared to be exaust, so I think she was trying hard. At this point I feel blind without the manual {which is on the way} so can anyone help with this? Thanks in advance, Denny
