'68 Johnson 40 hp not peeing HELP!!
Billy Bob
Hi Everyone<br /><br />Waterpump was replaced on this motor. Brother bought it on the cheap and was told it needed a water pump. Replaced pump. Did not pee. Took assembly apart and checked and reinstalled. Did not pee. Repeated these steps several times. Had to keep checking that woodruff key was in place. <br /><br />Brother was convinced that the earmuffs were just not able to put the water where it was needed. The water inlet on this motor is a slot near another object. Could not get a great seal. Repeated the steps from above AGAIN and this time started motor in a tub of water. Did not pee. <br /><br />Passages would allow water through them when disassembled. Motor was apparently not ran for very long because of the fear of overheating. Is this the "problem" or could it be? Is there a thermostat in this motor? Would it prevent water from coming out the peep hole until it has reached operating temp?<br /><br />thank you so much in advance for your help<br /><br />Billy Bob
