Hi Everyone. So I finally got my engine purring like a kitten, took her out to the lake and she did great for a few minutes, then I lost forward gear but still had reverse. I backed a decent ways back to the dock without a problem, got the boat home and noticed my power cable for my shift/throttle box thing had gotten hot and started to melt.
I took the cable off, cut back to good wire, re soldered the wire back in the little box, and now I find myself without forward or reverse. I'm not sure the problem is actually in the box, because even with it unhooked a test light is showing a dead short in both the forward/reverse wires (hooked test light ground to batt positive, touch the wires and they light up) I cut the forward/reverse wires just before they go into the lower end hoping to cut out a bad spot of wire, but they still show the dead short.
My question is, are these wires supposed to be grounded, or is it possible that I fried both of my solenoids when the wiring got hot? I should note that my ignition switch also fried, and I'm in the process of replacing some wiring to try to eliminate whatever caused the problem, but does it sound like I'm going to have to tear into this lower end, or are the wires supposed to be grounded?
