68 OMC Ball Gears
crazyinkc
I am looking at an old 68 IMP boat and the ball gears look pretty worn. I have been looking for the pre 73 gear every where, even NAPA with no luck. Is there a way to use post 73 parts to switch the the later style gears? Can I just change to later shafts?
Re: 68 OMC Ball Gears
If you have Any sense,.... At All,.....
You'll Keep Looking....... For a Different Boat.......
Those Ballgears will be the Least of Your Problems.......
Boomyal
Call Steve at Ryans Marine in Portland Or. He will know if they are still available or interchangeable. He is a great OMC resource. People send him OMC drives from all over the country.
503 282 8807
Tell him Gyro Gearloose told you to call.
crazyinkc
Thanks guys for the feedback. I did call Steve and he was very helpful. The ball gears are worn flat on one side but only about 10% in. Steve said as long as they are wearing flat and even, I should be okay for awhile. I only plan on running the boat for a few years and stepping up to a better boat. The boat is owned by a marinas owner and he has had the boat for years and it is in nice shape. He told me the same thing, just run with it but I wanted to get feedback from the guys here on the forum. Sorry Bond-O, I had already put a deposit on it so I guess I will go ahead and take the dive but thanks for the suggestion. If it turns out to be a pile of junk, which I doubt due to the overall condition, I will part it out and recoup my money.
Boomyal
Just be sure to run with the drive all the way down. The O/D tilt is not a trim unit.
