greenacres
- Mar 14, 2002
- 2
I'm trying to figure out how to properly set the points on this jewel. It has 2 sets of points and the book is not clear. It does not tell me which sets of points should be open when. The flywheel has 2 timing marks on them. Also, I suspect I have a bad amplifier. Can see no voltage from the amp to the coil. This thing is going to cost upwards of $300 bones and I want to make sure it's bad before I scrap the motor. Already put too much time and money into it to spend an extra $300. I am troubleshooting a no-spark problem. Compresssion is 120 per cylinder, brand new wiring harness, solenoid, and regulator. Need some help. I do have 12 v going to the amp, and can read 12 v going to the points when they are both open.
