rich lafollette
- Jun 9, 2002
- 4
I have a 40 hp 1969 Evinrude manual shift that I'm trying to get back into<br />Running condition. I have removed the lower unit and put in a new impeller<br />replaced the lower lube, new plugs, cleaned carb. 2 questions. I have a hose<br />hooked up to the motor for running purposes. Still runs kind of rough and <br />there is a hole right above the lower skag on the side and after the motor<br />has run for a while and I stop it there is some kind of foamy stuff coming out <br />of it, but does not appear to be the lower green gear lube, what is this hole for?
