22E6441
- May 29, 2008
- 376
I recently changed my lower units gear oil and it was pretty milky. I haven't had the boat in the water yet, but I've found one of the leaks.....the seal on the gear shift arm pin. This screw is above and forward of my drain/fill screw for the gear oil.....see attached. The gear shift arm pin is part number 23 as listed.
Can I remove this screw, put a new seal on it and reinstall? Or will this drop gears inside the unit requiring a full tear down?
