69 evin triymph 55hp safety switch issue
1961skiflite
Well I've been fighting this motor for a month to run good,but have had no luck.I went to start it yesterday,and it fired right up but is loading up on me.it seems to be losing spark somewhere,I tried to retire it and had no spark.so I went and adjusted the nuetral switch and it fired back up,is there a way I can bypass it
194269
Re: 69 evin triymph 55hp safety switch issue
Yes there is, but don't. You have other problems, if the engine is loading up, its not an ign. problem. Sounds like your idle jets are not adjusted right, may be carbs are flooding. Take a closer look at your fuel system.
