I need to replace a piston on a 1969 Merc 500. I figured I would be better off with a used piston then a new one not only because of price, but because when measuring mine vs. a new one, it seemed the new one was about 1/2 mm larger in diameter than any one of the 4 of mine (yes, I verified the part numbers are the same - mine must have worn a bit over the years). Seems this would put things out of balance - more weight on the new one, more compression on the cylinder with the new piston. My 3 good cylinders had 115-120 psi, so I'm guessing after I replace the busted one (sucked a reed) I don't want a whole lot more compression. Are these concerns I should be worried about? <br />Anyway, I cannot find anyone or any dealers who have a used piston(the only one I found had a crack on the head). So my next choice would be a Wiseco ($50 less than a Mercury), but even that would be pushing $100, and I've been told I could probably get an old powerhead for that if I could find one. Anyone have experience with Wiseco pistons, or know of any good places to get old pistons/powerheads?<br />Any insight to the above questions would be appreciated. If you happen to have a piston or an old powerhead of similar vintage you'd be willing to part with, let me know - sharidan@wowway.com. Thanks.
