6hp Johnson-HELP-idles great, but no power ??
Carpfisher
86 Johnson 6hp fires right up on a half a pull, no choke. But has no beans. Will not "rev up". Linkage seems correct. I can manually reach down to rev it and still nada.
Squeezing the primer ball doesn't help.
Disassembled the ultra clean carb. No debris or obstructions. Put a kit in it anyway. Hi speed jet that screws into the side of the side of the plastic pick up that sits on a gasket in the bottom of the float bowl is clear. New gasket and pick up tube replaced.
Motor has over 100psi compression and good spark, even though they are NGK's. I suppose this could be a really weird wrong plug problem but I dought it.
How about the timing advance setup on this motor? It seems to be mechanically activated rather than a spring loaded linkage set up like on my 70hp Johnson which was sticking and the spring was unable to overcome the stickiness, causing no power/no run problems and a confirmed fix !! So it doesn't appear that could be the problem but that is what I'm leaning towards, a timing advance problem.
This is the 6 with a lighting coil. I have the flywheel off now, but before I go digging in, I though I'd run it by the experts here. I don't see where there could be a problem since it's mechanical activation should overcome any "stickiness" that developed, tranfering the stickiness into a hard to turn throttle.
I have no manual, engine is not mine yet. Boat friend gave me 3 engines to try to get running. a 4 , a 6 and a 9.9.
4 and 9 are in bad shape. 6 can be mine for around 100 bucks if I can get it going plus it will be a great match for my 70 johnson. And the weight it right for the kicker bracket.
Otherwise it's 4 bills for a turnkey Tohatsu I see on CL.
Just trying to save a buck. I can buy a lot of fuel with that extra 300 bucks......
nwcove
Re: 6hp Johnson-HELP-idles great, but no power ??
Strong spark on both cyls??
raczekp1
as said abowe, problem can be powerpack ol one of the coils,
borow powerpack and coils from 9.9 (will fit for sure)and run this 6 hp with this borowed ignition components
Carpfisher
Thank you both, strong spark, both plugs, switching components from the 9.9 is a good idea.
Pulled the carb back off for DOUBLE checking-check, pulled the flywheel, without complete disassembly, timing mechanism looks clean and free of corrosion.
I see the adjustment at the roller cam may be off, doesn't look like it's making contact till a ways down the stroke of the throttle,
It's all back together and I will adjust and retest after dinner.
Thanks again for your advice..
F_R
You can almost bet the farm that it is running on one cylinder. It COULD be one of the spark plugs. Or it could be getting water into a cylinder. It could be a ruptured fuel pump diaphragm, flooding one cylinder. It would be extremely odd if it were a carburetor problem, unless somebody has screwed it up so badly that it is running way too rich (four cycling).
