To check gained rpm and speed you must check that with an induction tach along a GPS on water conditions as indicated. Throttle to 3/4 check achieved rpm/GPS reading, go wot check same readings. If boat is not correctly top inflated you could be excesively dragging hull on water, that's why feels there's no rpm/speed increase between 3/4 and wot.
If at 3/4 throttle or slight over the carb's pawl roller has stopped at the highest peak on the throttle cam before cam flattens out, just expect a slight rpm & mph increase at wot. Electronic gadgets will provide a accurate veredict.
Once checked with gadgets, check if that engines is correctly height seated, being a 6 HP under powered for that inflatable you must squeeze the max power out of that 6.
Happy Boating
