6R70B fuel pump diagram
kbert1171
my daughter "helped" me fix the motor by taking the fuel pump apart so we could rebuild it. unfortunately she did it when I wasn't there to see how it came apart. does anyone know where I can find a diagram of one so I can reassemble it properly?
Crosbyman
you need to read the doc a few times....it is tricky
​ the small springs and dome mushroom caps can drive you crazy by falling down all the time of jumping out of view....:cold:
I found it easier if you actually glue down the springs on their nipple supports with a touch of crazy glue and I also glue down the mushrooms on the springs with a touch of crazy glue
​when all done do a blow test air goes inlet to outlet but does not flow outlet to inlet. if it does start over again ...by reading the instructions
"​Patience brings joy" :joyous: . ..said the cookie have your daughter rebuild it....for a life long experience;)
