6t70 trannie haunting between 5+6
dolluper
At 82 k or 50 mph haunts like lock up torque in and out...pressure solinoid or wave plate any one have ex with this
gm280
Do you have an option to force it into lock up or keep it from locking up? I mean on some transmissions going from overdrive to third gear keeps the lockup from taking place. And then you can tell is the lockup solenoid is working or not. JMHO
wrench 3
First thing you need to do is get it scanned for trouble codes. There's a good chance that it's an electronics problem.
dolluper
Shifts can be forced using paddle shifters...no codes ...found pressure solenoid was flaky ...shifts like new now no more haunting...thanks
StarTed
Did you really mean hunting? Or is the problem haunting you?
