7 1/2 HP Johnson out board problem running
JIM4475
I have a 7 1/2 Hp Johnson not sure about the year but, it crank's within 4 or 5 pulls, but when I am running down the lake it will not run at WOT unless I hold the choke out just a little?? What do you guys think could be the most likely problem??
Thanks
Jim
:confused:
F_R
Re: 7 1/2 HP Johnson out board problem running
How old is this 7.5? If it is an old one with adjustable high speed knob, give it a tweak toward "rich". If it is a newer one with no knob, the carburetor needs cleaning. The high speed fixed jet orfice plug is partially clogged.
samo_ott
Bang on. And if your carb has not been cleaned recently, it would be a good time to do it anyway! :)
And I tend to think it's a newer one as if it was from the 50's most folks preface it with "antique... or classic.... or old..."!
JIM4475
This one has the knob and I tried adjusting that also, it also gives a little trouble starting after it has been running for a while. It is most likely the carb it hasn't been cleaned in a few years. Should I buy a carb kit or just pull it and soak it with carb cleaner?
Thanks
samo_ott
If you're going to the trouble of pulling the carb off and taking it apart to clean it, buy a carb kit for under $20. It will make it nicer and easier to fix up. I find that usually it takes longer to re and re the carb then it does to actually clean it. I personally I would never do that much work if I didn't put a new kit in it as it's cheap insurance.
Post the model # if you can though so we know what you have. It's on a small plate on the transom mount.
F_R
That's a 1980. Clean the high speed orfice. It has to be absolutely positively clean. Nothing else will do.
