why is it that my 94 superduty leaks out oil at the combo oil line/waterline that goes from the front driverside of the block back to the oil filter?????
the leaking point seems to be were it bolts to the front of the block, right were the gasket is, BUT
This only happens when it gets cold, leaks/blows out half quart then stops.
Is there an issue with the desighn, or is the preasure from the oil pump and the cold just effect that point.
thx
rob
thx
rob
