7.4 454 mag, no power under load
millertime016
Have a 454 mag, changed wires and plugs and when I put it in the water for the first time this year everything seemed fine until I put a load on it. Engine will max out at about 2000 rpm, ran great last year.
Checked wire order a couple times, timing is ok.
Any ideas, thanks for the help?
6meter
Re: 7.4 454 mag, no power under load
Need more info. Carb, EFI or MPI. If it has a carb, the jets could be plugged. Bad gas. Bad coil. Just a few thoughts.
millertime016
It has a Carb. I changed the cap, rooter, plugs, and wires.
Wire order is fine and timing is fine.
I am testing the compression later tonight and will check the gas later too, can?t see where that went bad over the winter but have heard crazier things happen.
