I'm guessing that the bullet addition and pitot were a kit that the two ports on top of the pitot is where the factory vac line went along with the yellow vac line, but previously owner drilled thru transom and went directly to gauge to fix issue since other line was cracked and broke when I wiggled it. Should I seal his hole and replace with stock routing?
