alindquist
- Feb 21, 2008
- 82
Hi guys, I'm about to pull the engine in My 1999 232 Cobalt and have a few questions I 'm hoping you guys can answer.
First things first
Engine is 7.4 gipwtr, serial number is 4112049663
I have the manuals and think I have everything disconnected and it's ready to pull but I'm not sure where to lift from. My dealer said that he thinks there are lifting points installed on the motor already. The manual makes no mention of this. I looked at the engine and there appears to be a lifting point on the front on top of the thermostat housing and 1 behind the cylinder head on the starboard side. See the diagrams below:
Cylinder Head 7.4GIPWTR - 7797468 - Volvo Penta
Cylinder head #25 (called bracket)
Cooling 7.4GIPWTR - 7797468 - Volvo Penta
Thermostat housing #4 (called bracket)
So the question is are these the lifting points and if they are should there be a third one the back side of the port cylinder head?
If these are not the lifting points then where should I be lifting this from.
Thanks in advance,
Aaron
First things first
Thanks in advance,
Aaron
