Hi, I have a 23' wellcraft with a 454 and was operating the boat at approx. 3800 rpm for a few minutes on a nice smooth stretch of lake erie and noticed the temp gauge up 5 + deg from where it normally reads (150) causing the secondary temp sender to emit a signal to the temp light so I backed off to 3300-3500 rpm and gauge dropped back to normal. The impeller was replaced approx. 2+ yrs ago with Im guessing at best 20 hrs of use on it. Im wondering how many items can be a factor to cause this increase in the temp. The engine is all original never touched and is 1990 vintage. The water pump on the block has never been replaced either. A new stat was just installed before use as well. Any input would be great .
thanks jim
thanks jim
