castawaymaxum
- May 27, 2010
- 3
I have a 1998 Maxum 2800 SCR with a single 7.4 Mercruiser Bravo 3. Last weekend, the starter stopped turning the engine over and was just engaging and spinning. After inspection, it was noticed that that starter was loose. I tightened up the first bolt and moved onto the second, which was not there and in the bilge. I retrieved it and saw that the bolt was broken. There is no part of the bolt in the block that can be grabbed. I understand that the true fix for this is to pull the engine and drill it out, and replace, BUT....
The block is drilled with three holes, where it appears that I can use a straight across bolt pattern starter motor. My question is has anyone ever replaced a staggered bolt pattern starter with a straight across pattern starter. Any thoughts on this idea?
