7.4 MPI Gen VI ring gear part number
Mischief Managed
The ring gear on the flywheel of my 2000 7.4 MPI is worn in spots and needs replacing. Mercruiser only sells the flywheel, but I know how to change the ring gear on a lywheel and can likely save 500 bucks by doing so. Does anyone know a part number for the ring gear alone? Does not need to be a mercruiser part number. I think it's a 14" flywheel and will accept Sierra part number 18-4516, but I'm not sure.
Mischief Managed
Bt Doctur
[h=1]G9293 - 1955-02 168 Tooth Flywheel Ring Gear[/h]
Genuine GM ring gears which were installed on all 1955-91 full truck models except without Diesel engines. This ring gear measures 13-1/4 diameter.
about $45.00
Fun Times
Looks like the Sierra number will fit too.
If interested, I believe if you call iboats and ask about the forum5 promo code discount, it may apply to this item as well. (14" GM flywheel w/ 168 teeth)
http://www.iboats.com/Ring-Gear-Flyw...view_id.870198
