Hello all, I recently purchased a 1999 270 SeaRay SunDancer with a 7.4 mpi and a 22p Bravo 3 drive with dual prop. When I purchased the boat in January of 2016 I had a survey done and a seatrial. Everything went well boat would top out at 4600 rpm as should. The surveyor did a compression and a scan and everything checkout out clear. Long story short, I have noticed that the rpm would drop when I go WOT , now I don't do this regularly but I noticed that my wake is not the same. The weird part is that some days it will do 4600 and others like today it would top out at 4200 rpm and at the speed the gps shows about 29-30 mph. However I will say that it was a bit of a choppy day not calm but I had my out drive all the way down and trim tabs all the way up. Then I slowly started to trim the drive up and the rpm would go from 4000 to 4200 and that was the max. The only spring maintenance thing that I did was change the oil and impeller. The surveyor at the time of the inspection told me that the plugs looked really good and near new so I did not bother with replacing them this year. Does anyone have any input to as what it may be? What to check and look for? Thank You
