7.4 MPI WOT Limit
GL2238
I have 2001 26' Sea Ray Sundancer with 7.4 MPI B3 with 24P prop. Problem is WOT which during one run was 4K RPM at 35 MPH (GPS).<br /><br />All other times, since ownership, RPM seems limited to 3450 to 3550 at 31 MPH. Techs indicated there is some kind of safety limit built into the ECM when a problem is detected. All gauges read normal (Oil 50 lbs-confirmed) (Temp 165-170 F - confirmed) [fresh water cooled] . Engine is smooth running at all speeds. If I go down to idle from a wot test run and place in neutral and run up, RPM is not limited.<br /><br />Are there any connections I should check to the ECM that might be causing the auto RPM limitation. <br /><br />A technician plugged in a computer test unit and indications of "General Warning 1" and "General Warning 2" came up along with "Oil Pressure". He does not know what General Warnings mean? Also, am I to believe the indications clear/reset by themself when faulted conditions are no longer present, or must they be cleared by the tech?<br /><br />Two other identical boats with the same equipment have WOTs between 4200 and 4350.<br /><br /><br />Any help would sure be appreciated.
LubeDude
Re: 7.4 MPI WOT Limit
The rev limiter on the 454 FI the Boss has is 4,800.
Don S
The WOT Rpms should be between 4200 and 4600 rpm fro that engine.<br />I'm not sure what the "General Warnings" are either. The lowest trouble code number is 14. It may be called different things on different DDT's (Code readers)
newport dave
General Warnings are specific to MEFI3 and MEFI4 and are assignable/configurable by the OEM. I know that some late model Volvos have riser temperature sensors that, when overheated, will trigger a General Warning 1 or General Warning 2.<br /><br />I am very familar with the 7.4 MPI, and was not aware that the General Warnings were used with this engine. :confused: <br /><br />As far as trouble codes, once a condition that triggers a code no longer exists, the code will still show on the list of trouble codes, but it should not affect engine operation (rev limit) at all. <br /><br />The code will still be stored until cleared. Did you clear the codes to see if they come back?<br /><br />Dave
GL2238
Tnx Dave: As a matter of fact I questioned the tech about the General Warnings 1 and 2 and he said he found out they apply to automotive only. It was first time he ever saw them. I took out the boat last weekend but he is going on a test run with me tomorrow with the tester attached. He can also confirm what warnings, if any, happened last weekend. This problem has got a number of tech persons stumped. All sensors, including MAP, are normal. Compression is right on the money. This configuration should yield 4300 or so at 38 MPH. Actually I run mostly at 2800 which is confortable with good fuel efficiency.<br /><br />Jerry
newport dave
GL2238,<br />Has a diagnosis been made on your problem? I'm very curious to know what it is/was. Bad ECM?<br /><br />Dave
waterone1@aol.com
The general one and two codes are valid for the boat. The are assignable, as they are just contact closures. I don't have a chart handy, but on the MIE (inboard version) general two is used for transmission over-heat. I believe that is swapped to the gear lube tank on the outboard models.
newport dave
waterone1,<br />You are right about General Warnings 1 and 2 being assignable discrete switchs.<br /><br />You may be right that a Trans O/T or Gear Lube fault will throw a General Warning 1 or 2, the Merc service manual indicates no code (just audio warning) for these events. The manual shows no code for Oil Pressure either, but there it is.<br /><br /><br />The manual shows four discrete switchs, but only two (Gear Lube and Oil Pressure) in use for a sterndrive model, and three (Trans Overtemp, Oil Pressure, and Load Anticipation Mode) for an inboard model.<br /><br />What I don't get is how he could have an Oil Pressure code and both a General Warning 1 and General Warning 2 on a sterndrive model. That would seem to be one too many codes. :confused: <br /><br />Dave
waterone1@aol.com
Dave, you are jogging my memory. The load anticipation (for inboards) is only a switch closure on the trans linkage that opens the IAC to raise the idle when shifting into gear. It will not set a fault code. General one is used on both (inboard and I/O) as low oil pressure. The second warning (#2) is either trans overheat(inboard) or lube level(I/O). I agree having both codes would be rare for an actual failure, but I THINK(wish my manual was here) they share a common ground to the ECM. IF that is correct I would be looking for a wiring harness or multi-pin failure to the ECM( or these were stored at different times). If I have a chance later I'll get out the manuals and try to verify this. I do agree that a non-active code should not be affecting performance. As you and others have suggested, clear the codes and get the boat on the water and see if anything comes back.
