hawkeye9802
- Jun 8, 2014
- 8
Hi everybody. New guy here so go easy! I am trying to sort out a no spark issue on my 7.4GL Volvo. It has run fine with no issues and after running for a few hours pulling the kids on the tube I shut it off for about a half hour and when I went to restart it cranked normally but didn't fire. I have checked the ignition switch and kill switch and they are not faulty. There is 8.5 volts at the positive terminal on the coil with ignition on. I had an extra coil in the garage and switched that in out of desperation but of course it didn't help. The coil high tension lead fails to spark to ground at all. I can't seem to get the links in the 'adults only section' to open. Can anyone point me to a discussion of trouble shooting the no spark condition for this system?? Serial number on engine is 3868102 as best as I can tell (the numbers on the sticker are faded and hard to read...) Thanks in advance for any thoughts
