7.4L Mercruiser oil and (filter) change
Collette
My first post. Did some searching re; title but was unable to find the info.
The engines are serial numbers B817223 and B817410.
the filters are remote mounted and i'm sure I can cross reference them when I get to the boat. The boat is a 1988 Sea Ray 34'. Would like to get recommendations, for oil viscosity and filter brand s and part numbers.
Would also be interested in info. for the Westerbeke generator, serial number
1552162-C707.
Thank you in advance,
Mark
Re: 7.4L Mercruiser oil and (filter) change
Ayuh,... Welcome Aboard....
For Filter Brands,... Wix is about the Best,+ Napa filters are rebadged Wix filters....
They'll cross the #s for you....
For the Oil,..??..??..??
Up in the "Adults Only" sticky at the top of the forum, there's a link to All the mercruiser factory Manuals...
Download the 1 for your motor,+ See what Mercruiser recommends...
Otherwise,... Oil recommendations usually turn into a Slugfest, due to the Many Opinions about it....
I use Mobil 1, 15W-50 in My motors....
And,..
In Reality,...
Any oil that can be bought off the shelf at Wallyworld will run in your motors,.. Just Fine....
Collette
Thanks Bond-o for the quick response, however the link seems to be dead.
Don S
The link works, but it's 485 MB in size, it's huge, and going to take a longtime to download even with a cable connection.
