What does the starter on my 7.4L Mercruiser draw for current? I'm planning on installing a battery switch in my 1993 Cruisers 2670 Rogue. There's a medium duty switch that is rated at 250 amps continuous, 360 amps intermittent capacity and then there's the heavy duty rated at 380 amps continous, 850 intermittent. The minimum rated battery recommended for the 7.4L is 650cca/825mca. I don't want to overkill it but I do want to be sure it's not going to melt the contacts.
Any thoughts on brands? Perko vs. Blue Sea
Went to start it this past weekend out on the water after an hour run and my 3 yo starting battery was getting weak. Almost had to get out the jumper cables but it finally started.
Thanks
Dave
Thanks
Dave
