I have twin 7.4 L Mercruisers with thunderbolt IV ignition and v-drives in my new to me 89 SeaRay.
Issue with starboard engine only. Engine starts fine, idles fine runs out from the marina at no wake speed fine, gets up on plane and runs great. When coming back to the marina and slowing to below 1000 rpm it starts to run rough. Sounds like someone pulled off 2 or 3 plug wires. Won't idle but never stalls. Tach will bounce around at 200-400 rpm.
Get back to dock and let it sit for 20 minutes and it will fire right up and run fine. Does this like clockwork every time I go out.
Both carbs rebuilt and tuned(even swapped carb from other engine, same issue) so I ruled out carb.
New cap, and rotor this season.
Changed fuel filters.
New coils.( one on port side had a crack so I replaced both)
Plug wires seem newish. Have misted them with water in a spray bottle while running and it doesn't cause any issue.
Tested engine with vacuum gage( little low at idle but the engines are a little tired and have 1700 hrs. Port engine has same reading on vac gage).
Compression is on the lower side but again the hours are up there and the other engine is the same.
Seems heat related but not sure what.
Engine temps are 145 all day long.
Exhaust elbows seem ok for water flow. Hot on the sides but cool to the touch on the top.
Any ideas or has anyone seen a similar issue?
Thanks,
Adam
Thanks,
Adam
