7.5hp Gamefisher, runs at idle in full choke, half choke, and wide open. I can put it in forward, and it runs in full choke. In half choke in forward it runs 5 to 8 seconds then shuts off. In Wide ope in forward, it shuts off in 2 to 3 seconds. It will idle all day in forward in all three settings, but in half choke and run, as soon as I give throttle it shuts off. Carb is VERY clean, float not sticking. Air vent open on tank, even loosened the cap, and even taken off. I am going to replace the hoses inside the engine housing, and the hose and pump bulb coming from the tank tonight. Anything else I should look for?<br />
