7.5 Merc reverse lock engages in neutral
huntin dawg
Gents,
I just finished replacing the reverse lock rod retainer clip on my 7.5 Merc. In forward gear it releases so the motor will tilt and engages in reverse as it should but it also engages in neutral. Is it normal for the reverse lock to engage in neutral not allowing the motor to tilt?
Thanks,
HD
achris
More fish than mountain goat
Re: 7.5 Merc reverse lock engages in neutral
Gents,
Thanks,
HD
Yep..... Can only tilt the engine in forward gear... If it was unlocked in neutral, then it would kick up as you pulled the starter cord. :D
Chris......
huntin dawg
Chris......
That makes a ton of sense. Thanks!
I feel like a dummy for not thinking of that!
Regards,
HD
